Limitations of PTP
The following are the limitations of the implementation of PTP:
- Layer 2 transport is not supported.
- IPv6-UDP transport is not supported.
- Multicast event messages are not
supported.
- Peer-to-peer delay mechanism is not
supported.
- PTP datasets are not maintained for
end-to-end transparent clocks.
- Domain number cannot be assigned to
- Boundary clock does not support
synchronizing clocks across multiple domains.
- Distributing clock frequency recovered
from SyncE or from BITS or from a TDM port over PTP is not supported.
- Ordinary clock master (Grandmaster) mode
is not supported.
- Synchronizing system time with the time
recovered from PTP event messages is not supported.
- Time of Day (ToD) output and inputs are
not supported.
- Unicast message negotiation on clock
ports is not supported.
- PTP cannot be used if network clock
source is configured as BITS.
The following limitation also apply to 7520 and 7720 series switches:
- Stacking with PTP is not supported.
- PTP transparent clock is not supported.
